- Joined
- Jul 18, 2011
- 19,076
Greetings,
I have a question about adjusting the throttle linkage on one of my Merc 7.4L MPI engines. The Port engine throttle linkage is currently out of adjustment and only reaches 84% of the throttle range on the TPS read-out (Rinda Diacom)
This with with the throttle lever at the helm full open - pressed hard against the instrument panel - so that is all the travel of the lever itself.
I assume I would need to adjust the linkage back at the engine to get the full travel at the TPS sensor.
*** My question is by doing so will it mess up the adjustment on the other end of the throttle range (i.e. the idle setting)? *** Is there a trick or procedure to adjusting the linkage for the MPI engines that I need to consider?
