66stingray
- Joined
- Nov 8, 2015
- 12
Trying to get some outside perspective on this. Boat is a 05' 25ft Tracker Marine Tahoe with a I/O 350 MAG MPI, Bravo One drive. Last year I overheated due to overdue risers and manifolds. Shut it down before any damage occurred. Got new risers, and manifolds put on with a new raw water impeller and was back on the water before the season was over. Boat ran fine towards the end of the season, but started to notice that my water temp gauge was barely registering. After putting it away and starting this season, I have been chasing this rabbit hole for a while. Took the thermostat out cold and noticed it partially stuck open. Easy enough, replaced it along with a new plastic sleeve and gasket with OEM. Afterwards, temp got to normal, but would see cyclical fluctuations while underway. Normal temp, then cool down and shoot back up to normal. Changed the temp sender (for the gauge) and no change. Verified temp fluctuations with an IR temp gun on the tstat housing and its legit. I changed the tstat again and for a couple of weekends it was acting normal, that is warming up and holding normal temp. It. It now started to exhibit the same symptoms.
I have since installed VesselView and have some additional data. Water temp never goes above 158, when it fluctuates, but I have seen it go down to as low as 109, verified by IR gun on tstat housing. Disclaimer for water pressure reading: I took my sensor out (from the power steering cooler line in the back of motor), cleaned it and took some ohm readings. The sensor is not within spec from what I found online, so cant be certain that VesselView readings are accurate. Neverheless, at idle, typically it is about .07 to 1psi. At moderate crusing speed, 3,000 rpm, it never goes above 3psi. What I did notice is that my water temp fluctuations start when my pressure briefly nosedives while at crusing speeds (from 3.0 psi, goes to as low as .5psi for a few seconds, again not sure if these readings are accurate). This starts the water temp to cycle up and down along with it, but not on the overheating side, it just keeps cycling cooler to the point that I got a low reading of 109. This usually happens later in the day. My exhaust manifolds get as hot as 210 while crusing, with risers about 100-110.
I was hoping that I can finish out the season, before I pull the raw water impeller to take a look, but cant see how that would cause temp swings to low readings. I thought of 3 things: 1.) the circulation pump is freewheeling and causing the swings. 2.) my tstat housing has some corrosion on the inside lip where the tstat seals and is letting water getting through/not holding heat in the engine at higher revs. At this point I ruled out the tstat (having changed 3) and verified the temp fluctuations are indeed happening. 3.) A collapsed hose somewhere, maybe in the waterpickup because I dont see any hoses collapsing inside the engine bay. Anything else I should be looking at?
