Chrismonroe31
Thread starter- Joined
- Aug 13, 2020
- 8
Hi guys this is my first ever cry for help in one of these forums so please forgive me if posted in the wrong place.. I just bought a bass boat with a 1987 Johnson 150 hp VRO outboard. Owned it for about a week, I’ve fired it up on numerous occasions and haven’t had any issues whatsoever it runs like a champ. I did a compression check on the motor, then the very next time I fired it up after about a minute or so of running in neutral at idle speed I started getting a warning alarm from the control box. This is not a steady constant beep, it is a beep-beep-beep every second or so with a second or so break in between. This I believe is the VRO failure / no oil alarm. The motor is pumping great water and all cylinders stay at approximately 140° F. I know it isn’t overheating. Also, the previous owner had disabled the VRO injection, the oil line is plugged and sealed and it’s only running pure 50:1 premix. I know there is no water in my fuel because it’s a brand new tank with brand new gas and yes it is mixed properly. While the motor is running I have visually inspected all fuel lines and carburetors and see absolutely no leakage anywhere. Fuel filter is clean as a whistle. Does anyone think this could be a false alarm? I know for a fact I’m getting oil because it’s premixed and the motor is being properly cooled so I’m honestly stumped. Yes this same tank of premix was what I was using all week when the motor has been fine. It only started doing this after I compression checked all 6 cylinders. Does anyone have any ideas? Thank you so much for any help that can be provided.
