I’ve been trying to tackle this issue for the past month and can’t seem to find a solution. I have an 89 470 mercruiser 3.7 165hp. Cylinder 3 seems to be mis firing as it’s idling very rough and I can’t seem to pin point the issue. I’ve replaced the Ignition coil, the condenser and the points. I have spark to all 4 wires leading to the spark plugs and even the 3rd one that seems to be mis firing. Compression is strong on all 4 cylinders too and we even replaced the fuel pump. However when I pull the plug from the distributor on the 3rd cylinder there is no change. Spark plugs are brand new too and all voltage was measured so I’m not too low. Am I missing something ? We plan on changing the spark plug wires and distributor cap tomorrow as well, any help would be appreciated
