catfishcarl99
Thread starter- Joined
- Apr 25, 2012
- 723
1980 evinrude 115 v4. the old time base was showing open on one lead with multimeter. replaced it. replaced stator while i had flywheel off. the coils are brand new less than a month. Today i got 2 new power packs in. just put them on. the entire ignition is new. not new used but new never installed. cdi timer and stator. cdi coils and seirra packs. i have no spark on top right side bottom on left. stator tests 599 on both leads in ohms resistance. normal is 450 to 600. the timer is getting 30-32 ohms on both the blue and green wires when ohmed to the white and 60's green to blue. both sides. normal. so they test fine. somewhere between there to plug wire im loosing two cylinders with all new components. any advise?
