Outboard alarm sounds with engine turned off
James Mcc
Have a problem on a 40hp 4 stroke Yamaha alarm sounding even when engine turned of and key removed ?
Texasmark
Had that happen to a customer. The alarm itself was shorted. replaced it and all was well.
That's interesting. On Mercury engines the alarm voltage is supplied via the key switch in On and Start. If the post was for a Mercury I would say the key switch was in need of replacing due to bleed voltage internally pin to pin. Course to go with that you would have to add a bonafide alarm simultaneously.
