I've got a couple of 94-95 2 stroke Mariner 60hp engines. Both have compression issues, but I'm hoping to rebuild a good one out of the two by honing one block and using the best of the remaining pistons and rings. I've got 105psi across all three cylinders cold, but she runs rough and compression drops to 90psi when warm. I thought PSI went up when everything had warmed and expanded?
I could spend money on getting her rebored and fitting a new piston kit, but I'm concerned about a cracked block as well. Any advice on checking the jacket for leaks?
