Hello,
I have a DPS-b drive (s/n A204006) that lifts slowly when I rev in reverse above about 900 rpm. I pulled the boat from the water and checked the fluid level and added about 2 oz. Replaced the o ring in the cap (cap hissed when I originally removed it which makes me think it was sealed) and could not find any leaks around the lines or cylinders. I could life the drive by hand with a decent amount of force. Cycled the drive up and down and checked level again but it still occurs.
It doesn't seem this drive has a reverse lock mechanism to keep the drive down? A friend thinks that maybe it could be the cylinders have some sort of internal limiters to keep the drive down when in reverse. Is there any way to test this as each cylinder is almost 600 and the trim pump which seems to be working fine is about 1200. I would prefer to not have to open any lines and replace if possible due to potential leaks that are not already there.
Any help would be appreciated!
Thank you!
Thank you!
