OptsyEagle
- Joined
- Sep 13, 2006
- 1,367
Sounds like it is running normal to me. The way that motor works is as the RPMs increase the amount of water pressure from the pump increases. As that happens the direction of the flow out the exhaust relief hole changes. At the beginning, one is lucky to feel a mist because the T-stat holds most of the water back but once that opens you should see flow like a stream out the back but the angle of that water will move towards and away from the midsections as the T-stat opens and closes and the RPMs increase and decrease.
Anyway if you ran it for 2 hours and the powerhead is just warm to the touch it is probably working fine. If it was not pumping water around the engine correctly your motor would be dead by now.
