I changed my outdrive !!!
pscott66
Hi All
K so I had to swap out my outdrive this year. I have a 97 Mariah 18' bow rider. It has a 4.3l lx Gen II engine and an Alpha 1 Gen 2 drive. Last year's drive was a 1.63 ratio, with a 17" pitch prop. The hole shot was amazing and top speed was around 60k. Although I could over Rev it if I wasn't careful
This year the new (used) drive is a 1.84. I used the same 17" prop cause that's what I have ... took it out and it ran like a bag of poo. All my research says that the 1.84 drive should be a better ratio for the V-6 engine, and a 17 pitch prop is pretty light I think. So what the he'll !!!
you sure on the ratio? there is a 1.81:1 and a 1.94:1
Mercruiser Alpha 1 Gen 2 (1991 & Newer)​
EngineHPLiters/CIDCylindersGear RatioTooth CountYear
3 Liter1303.0/18142.024-241998-2005
3 Liter1303.0/18141.9420-241991-2005
4.3 Liter1754.3/26261.8117-191991-2005
5.0 Liter2305.0/30581.6124-241991-2005
5.7 Liter2605.7/35081.4720-221991-2005
also, not sure of any Alpha 1 Gen 2 drives with a 1.84:1 ratio. a gen 1 yes, behind the 3.7 and early 4.3's however not an A1G2
Mercruiser Alpha 1 (1984 – 1990 Models)​
2.5 Liter1202.5/15341.9820-241984-1990
3 Liter1303.0/18141.9820-241984-1990
1651653.7/22441.8417-191984-1990
1751754.3/26261.8417-191984-1990
180, 190, 4701803.7/22441.8417-191984-1990
You trying to convince yourself? You swaped out the better A1G2 for an A1G1 or MC1.
Ayuh,..... As in How,..??
It should be revin' to the moon, 'n goin' nowhere,......
Yer gonna need a bigger prop to match the drive ratio,.....
Benchmark: 68,000th post
briangcc
Ok...stupid question alert...
Mine is the 180HP variant of your 4.3 v6 and it came with the 1.6x ratio A1G2 drive swinging a 4 blade 18P prop. IF you got amazing holeshot and top end, why, oh why, did you change the outdrive to a ratio different from what you had already and were happy with?
Seems to me a slight tweak on the prop if you were hitting the rev limiter would have gotten ya further...and more than likely cheaper....
Scott06
Hi All
Get a 19” pitch prop and you will be the same as you were with the taller drive ratio
I run a 1.82 drive with a 5.0 after swapping a 4.3 out and went from 19” pitch to 21” pitch and it works fine
pscott66
At the end of last season it blew the oil hose to the drive and water must have got into the lower gear case, and it froze .. I tried to get it rebuilt but no dice .. now I'm thinking swap out the top end of the old and bottom end of the new.
pscott66
Oh I don't drive like that .. we use the boat for wakeboarding and top speed for that is around 20 mph. but the hole shot is everything ... 19 is the correct prop. But I dropped it a notch to find 1st. gear
QBhoy
And that 4.3l is different... only 175 hp ... mine is 4.3lxgen+ 220hp.
Not sure about your idea of 220hp. As far as I know, only the 4.3 mpi and a recent reman from quicksilver would be 220hp.
QBhoy
Hi. Yeah you’ll need more than a 17” with that ratio. At least a 19, more likely a 21
