Dawn Tolliver
- Joined
- Jul 3, 2021
- 25
1971 silvercraft 140 mercruiser 3.0? 4 cyc. Cant seem to align boat moter with tool. Dropped front mount ALL the way down. Still needs to go lower. Upon looking found stringer bolts finger tight and to small, switching them to larger ones to fit mount holes. Also theres a 1/2 inch board under the mount. About the same I need to go down. Put a board under top of mount at deck level and stepped down on it. I moved the front of the moter up about an inch. So I should be able to slide board out no problem. Then when I rebolt it should give a better bite to. UNLESS SOMEONE! Can tell me how to lower my moter some other way? Looking in the coupling hole you see more of the top of it than the bottom. The tool no matter what adjustment wont go in more than 1/2 inch? Adjustment does not look like it changes even if I take it all the way high to low? Someone told me the A tool does not work on these older boats.That the tool only goes in so far. It's a 4184822 That maybe it's a Tr or Trs? Dont know much about boats to figure this out. Went on LINE but no help with alignment problems but all say the same thing. Adjust till tool fits. But dosnt go into details on how to do anything else to fix the problem. The stern was off for a year. Dont see how that can raise THE moter. Came off easy. No rot anywhere! If I take that board out will it screw up anything else? Help please want to save my summer!
