shrimpman123
Thread starter- Joined
- May 21, 2008
- 40
Morning All !I be got a 94 70hp force ,with bad lower unit bearing carrier …I’ve done everything but bust it out with a chisel …soak heat..pull ,,soak ..heat..pull over and over ..am I missing something?this carrier should come out after removal of the two fasteners on the carrier itself correct? ,,I’ve heated around the mid-case and near top edge where the carrier should be mating with the lower unit case …quick question what’s the small screw all the way forward ..see attached pic ..any help
Greatly appreciated !!
