nitsuj
Thread starter- Joined
- Jul 22, 2003
- 483
Hi gang. Hoping you all can help. I have a 1991 Gibson houseboat with twin 318's, v-drive. Last weekend my starboard impeller tore itself apart. It was replaced last season, so I thought maybe it was just time. Now I'm thinking it starved for water and over heated. I caught it early by not seeing water coming out of the exhaust. Boat never over heated, or even came up to operating temp. So I got a new impeller. Before installing it, I blew air out of the intake line, no blockage. (A couple vane came off the old impeller but I found them.) I also flushed the system both ways with a hose. No blockages. So I put it back together and fired it up. No water from the exhausts. I'm at a loss. I've checked and re-checked everything. I have flow everywhere with a water hose or air. Every other boat I've had, the pump is below the water line, this one, it's above the water line so I know it has to pull the water through the inlet hose, but it's not. At least not enough. It's drawing enough water to wet the insides of the lines, but not enough to get water out of the exhaust. Do I need to prime it somehow? Or pressure test the system for leaks? I've had a lot of I/O's but this is only my second season with a v-drive.
Thanks in advance.
Thanks in advance.
