WalleyeSniper
- Joined
- May 15, 2018
- 108
Sometimes I say the neighbors cat came by and pissed on my glass.
The main ones you're gonna hear or see used:I read it, I think I should download it and study it. Iβd like to talk the talk properly and understand the abbreviations.
Thanks man, I'm trying. Definitely probably some room for improvement. But, I'm getting the hang of the mixtures now.Looks to me like youβre doing a fine job!
You know, I kept having all those little scragglers and saggy divot dot things, and etc. Then I just kinda lightly brushed over them to smooth them out with a little 2" chip brush. But I was afraid I was gonna cut into the radius or mess up that perfect curve, so I may still need to go in and do some final touch ups before tabbing.I learned a trick here about putting down fillets (I forget who told me) that helps you avoid βcraggiesβ that make it hard to lay the tabbing down smoothly. Just brush the fillets, before they kick off and harden, with some catalyzed resin. Makes the fillets nice and smooth without sanding.
For the fillets you can also keep a spoon handy to smooth out everything.
For you transom bilge drain fill solid with hairy pb. and flush. look into bilge drain examples you may use.
Eventually you drill it out and install it. The bene is there is NO wood in contact with water when stern is sitting below water .
Makes total sense (and obviously why I did it after you had mentioned it, so thanks for that!).For the fillets you can also keep a spoon handy to smooth out everything.
I'd have to go back and look what I used. Mine unscrews to let water out but it stays in place and doesn't come out unless I use add'l turns for such. Also chrome or stainless with rubber O rings that can get replaced.
On another note because of it being stainless you need to drive 1 bolt thru to inside bilge and ground/bond it so it doesn't corrode. Bonding is another whole topic that needs researched.
Uh oh... I think I used too much peanut butter at once, because it's curing hot right in front of my eyes (about 30mins after laying it now)... Do I need to put a fan on it, or am I already screwed, or is this normal? LolI'd have to go back and look what I used. Mine unscrews to let water out but it stays in place and doesn't come out unless I use add'l turns for such. Also chrome or stainless with rubber O rings that can get replaced.
Oh... lol... Maybe in batches to final. Forgot about that. Yup just check for hairline cracks/fractures.. Might have to redo.
Been there done that. If its too deep or wide for the fill then you get the heat. If you have fractures then knock it out and fill back in layers not as deep.
Ohhh the memories.
I have a couple of those in stock here still, so I may just use one of those. My boats stay in the water really though, and I guess this one is a little big to be trailering much anyways. So, probably go with one of those. Just have to keep a spare in the boat and in the glovebox for those rare one-off occasions.This is what I used. Simple, effective, lasts forever. I keep a spare plug in the boat and in the truck.
Seadog Garboard Drain Plug Only with Pin
Garboard Drain Plug Only w/Pin Features: Made of pressure cast bronze Tested and accepted for labeling and Listed by the UL laboratories Flange diameter is 2" Plug diameter is 1/2" NPT Plug has square top for wrench or socket wrenchwww.iboats.com
Where do you get the spare bronze plugs from? Never mind - I see that iboats also sells spares.This is what I used. Simple, effective, lasts forever. I keep a spare plug in the boat and in the truck.
