Seawilly1421
Thread starter- Joined
- Aug 19, 2021
- 4
I have an old set of dual actuator(per tab) Bennet trim tabs. This year the port side tab goes down normally but will continue to go down when the up button is pressed. The port side tab is working fine. Pump has power, reservoir is full, sounds and looks normal, no leaks on the actuators or through our the system. What might cause the actuator to go down regardless of the down or up button depressed?
