MidwestFishingChannel
Thread starter- Joined
- Aug 22, 2021
- 16
Preface: Stuck unknown object in water and broke prop, Limped to shore in forward.
New prop acquired, but stuck in foreward,
Removed cotter pin from linkage on the motor to free up shift lever that travels under the powerhead to the vertical shift rod. Seems as if the shift linkage is free and flops right to left without resistance.
Can see through a gap at the top of the lower unit and observed Vertical shift rod moving.
Should i take this to a shop for a full teardown OR is there access when removing lower unit to possibly repair missing/disconnected bolt at the lower unit connection of shift rod?
Have built Car engines from the bottom up but never boat anything lol
