Hi all,
Among the things I didn’t think I’d have to worry too much about, I’m now finding that my stern drive is perhaps in need of a lot of work. This is an alpha 1 gen 1, around 1984. First thing is the lower unit. Ive removed the water pump and when I turn the driveshaft I get a sound that I don’t like at all. There is also some very rough feeling to the shaft as I turn it. And there seems to be a little sideways slop in it. I am attempting to attach a video. If that doesn’t work, just suffice to say I don’t think I put this unit back into service without
stripping it down. I’ve never rebuilt a lower unit before but it doesn’t look like rocket science. My biggest concerns are things like shimming and pre-load. I’ll take all the tips and advice I can get, along with links to the best instructional videos (I have a Seloc manual). Also note in the photos that the upper part of the shift shaft bushing has fallen apart, which I think might have occurred due to freezing. One thing I noticed is that the volume forward of the shaft has clogged up and wasn’t draining out of the weep hole, so maybe I got some freeze breaking of the bushing? What other issues might cause it to disintegrate like that?
The other issue is that The upper gear case seems tight. That gearcase has been rebuilt before. It takes a fair bit of effort to turn it, though it seems fairly smooth. Is there a guideline of how much torque is too much to rotate the input shaft (with gearcase separated from the lower unit of course)?
