tomconnolly
Thread starter- Joined
- Jun 23, 2021
- 55
Just rebuilt the motor. Didn't have this issue before rebuild. Carbs were rebuilt 2 year ago by PO. But the bottom carb idle screw has little effect from lightly seated to 2 turns out. I've set the timing to 5 atdc, then 0-2 btdc. Adjusted idle timing a dozen times trying to solve this problem. No positive improvement. Tested spark on all 6 cylinders with timing light. Compression was under 100 in most of all cylinders when tested after rebuild, about 1 hour of run time, but I was hoping rings weren't seated yet. Haven't checked it again.
I rebuilt fuel pump when I rebuilt the motor, but the online fuel filter between carbs and fuel pump gets air in it, over half air, when idling. Pumping bulb fills filter then it somehow gets half full of air again as it idles. Filter fills at full speed. Is this air in filter issue abnormal or ok? No leaks between pump and filter. Replaced bulb 6 months ago. Fuel lines appear nearly new black glossy jacket.
Some ideas I have:
* Pull gas line out of tank in case there is a filter on the end that is clogged. Is there typically a stone or other filter on the end of fuel line in the tank?
* Install fuel pressure gauge after fuel pump and see if I have pressure problems at idle.
* Replace fuel filter. No leaks apparent.
* Rebuild the bottom carb.
* Redo link and sync. Arrow is 1/4" right of alignment line when timed at 0-2 atdc...
Any advice is welcome. I'm still struggling with this issue after hours of using muffs and 5 times in the water since the rebuild.
Some ideas I have:
