jerryjerry05
- Joined
- May 7, 2008
- 18,158
This problem and similar problems, when it happens is the hardest thing to troubleshoot.Damnit. Pinched wires on the stator and totally created an open circuit.
Live long and prosper.Non-logical self inflected faults are difficult to troubleshoot and this is the reason to me careful and logical in your working.
Jumping from thing to thing and failing to be careful generates many problems that could be avoided.
Intermitted connection on the trigger wires, inspect the trigger-wires/terminals for the one that's not firing
Ok here she is running on 2 cylinders, then if I touch the throttle even a little, it jumps over to 3.
You can SEE and HEAR this.
any theories to why?
They both have 50 ohm resistance as per spec, they seem to be fine physically.Intermitted connection on the trigger wires, inspect the trigger-wires/terminals for the one that's not firing
Could this be some other issue with the trigger and should just replace the whole damn trigger?Intermitted connection on the trigger wires, inspect the trigger-wires/terminals for the one that's not firing
Sure, change the whole thing or one wire has break when moved in a certain wayCould this be some other issue with the trigger and should just replace the whole damn trigger?
Yes, I hear you on this one, I’ve done it — trigger and stator check out solid. No change in resistance. This is how we what was initially wrong, my leads had all been open, the wire was old and cracked at the terminals. 4/6 lolYou could try removing the trigger coil and carefully inspecting it and checking the resistance with your meter while you flex the wires. If you can localize the problem perhaps you can repair it. (carefully)
I have inspected the trigger leads, there was indeed a problem with it which was repaired. All trigger leads are now working properly.Thought I mentioned bad connections on the trigger leads???
1988/85hp: started off with an intermittent miss, once the motor got hot the miss went away.
Then the miss became more pronounced and would miss every now and again under power.
Then it became a constant miss.
One lead from the trigger, I found the wire had broken under the shrink wrap at the connector.
As I was fixing this another wire came loose.
I just replaced ALL the connectors, even the stator leads and the leads from the wiring harness too.
Never had another miss.
Do the tug test on the wire/connector.
Re-reading this -- I will double check the trigger wires.Thought I mentioned bad connections on the trigger leads???
It is possible that it is. try swapping coils. that would be the next easiest cheapest trial.swapped coil 2/3 and the same problem occurred on coil 3.
so it’s either coil 3, CDI 3 (which is its own unit), or wiring still.
going to swap CDI circuit to the spare circuit, see if that does anything.
is this logic???????
