1987 Johnson 48hp doesn't run well with Cowel on.
Benjamin12
Hello everyone. I have a 1987 Fishn Ski Barge with a 1987 Johnson 48hp. I bought it non running. Cleaned out the carbs and new fuel system. When I ran the boat, it would not plane and sounded like the engine was running rich. I took the cowel off, cleaned the spark plugs and ran it. The engine ran well with no issues. The moment I reinstalled the engine cowel, it had the same problem. I took off the cowel and it run great. The cowel is not obstructed. The carbs do have the silencer installed. Has anyone had this issue before? If so how was it remedied? Thanks.
juno pierrat
could be a bad gasket between engine block and mid section, pulling in exhaust gasses
Could be sparkplug lead shorting to the cowling latch..---Yes I know cowling is plastic.----And it is a good idea to install a new impeller on a new to you motor.-----Change gear oil too as gearcase is not known to be robust.
Benjamin12
Impeller and gear oil are new.
tphoyt
Check all the wiring to be sure nothing is lose and able to short when the cover is on.
check for lose Insluation in the cover that could get sucked into the intake on the silencer.
Run it at night in the dark and look for anything arcing move the wiring around with stick if need be. Video of the motor running would be helpful. Both with the cover on and off.
Replace the plug wire.----I don't think removing the latch is a good idea !!!
