First compression test ever V6 4.3, how much oil into cylinders? how to do it right?
Kubaat3lover
Hello folks,
i will do my 1st ever compression test on 2005 V6 4.3 Mercruiser,
I want to do dry then wet, but how much oil i should pour into the cylinder for the test?
All plugs out, WOT then 5 cranks per cylinder, am I right?
Thanks
i wouldnt bother doing them wet
however if you really want to, just a brief spritz of WD40 is all that is needed
new motor has 150 psi on each cylinder
good motor has about 140 psi on each cylinder
worn motor would be 120-130 psi on each cylinder
bad motor would be 100 psi or less
if you read higher than 150 psi, your gauge is off or you have oil in the cylinders
Kubaat3lover
Do you know the way how to turn off the spark?
because im worried of cranking the engine with all the wires disconnected from the plugs...
MichaelBC
Disconnect the plus wire of the ignition coil of unplug the ECU
Kubaat3lover
Thanks Scott, i will look for gray wire on the coil and ground it to the engine block.
tank1949
Buy a good manual before proceeding. UL thank me later. Good luck!
Kubaat3lover
Oh, the guy here mentions about grey one
I will just remove "+" from the ignition coil or pull the coil wire off the distributor
Kubaat3lover
Haha as always I love your sense of humour ;)
ok, to be 100% sure, heres a diagram for 4.3
I have to remove "A" from the rotor cap (1) and ground it to the engine?
or go to your controls and pull the man overboard lanyard (which kills the ignition to the motor)
Kubaat3lover
Got it, but also found info from Mercruiser that "
IMPORTANT: Ground the ignition coil wire (that goes to the distributor cap) directly to engine ground stud to prevent a possibility of a spark from the disconnected spark plug wires. When using a Remote Starter tool to crank the engine over, some engines may have the ignition coil energized by the ‘R’ terminal in the starter solenoid even though the key switch and the Lanyard Stop Switch is in the ‘off’ position."
your 2005 doesnt have points
it also has a PMGR starter, so no I/R terminal
Kubaat3lover
Thanks I owe You one,
on Friday or Sunday i will be back with the results
