KesselRunner
Thread starter- Joined
- Jul 22, 2020
- 24
Been working on restoring an old powerboat with a 2 stroke 115 hp outboard.
Recently installed the new plywood core in the transom. Did it from the inside using thickened epoxy.
My problem:
After the install it feels rock solid. But, I have found some voids where it seems I did not get enough clamping pressure. The location where I got a good bond and where there are voids between the plywood and outer skin can be seen in the attached figure.
Since the larger center regions of the transom got a good bond I do not feel like ripping it out again which I could only do by completely destroying both plywood and skin given that there is proper adhesion on the greater part of the surface.
As I see it I could either remove the skin in the regions where I have found voids from the outside which would allow me to do a real surface prepp, fill with thickened epoxy and then re-install the skin with bevelled edges and new glass.
Or I could just inject slightly thickened epoxy in these areas but I'd really like to hear some thoughts on how good that adhesion can be expected to be as I cannot sand the surfaces and the plywood has been covered in a layer of epoxy so it's actually a cured epoxy to cured epoxy bond that would be happening without any surface preparation.
Filling the voids to stop moisture from accumulating in these areas are of course something I will prevent by just filling these pockets with a syringe but what I want to make sure is that it is structurally sound. Advice and thoughts are much appreciated.
My problem:
