Chantres83
Thread starter- Joined
- Sep 11, 2021
- 8
Hello good evening I have a 2011 yamaha f150txr with 800h regular maintenance 200psi compression on all cylinders, the problem I have is the following, for about a year it has an intermittent fault sometimes it works well and accelerates at more than 5000rpm for several hours, but many times I can't go above 2000rpm, once it goes over 2000rpm the engine starts to fail as if it stopped working several cylinders, it doesn't matter if I accelerate to 3500 or 2500 all at once it always fails after a couple of seconds I lower it to 2000 and it works again Again, to get out of the failure what I do is lower the accelerator and raise it again, this I have to repeat it many times until it fails again and I can continue on my way, it is really frustrating, what I have done to him check the fuel tank all right I use gasoline without ethanol change of all filters including cleaning and replacement of VST filters change of injectors change of coils and spark plugs change of TPS sensor visual check of wiring harness all good There are no alarms or codes in the ECM fuel pressure good even with the failure, for me it is an electrical problem but I still cannot find what it is, and I have seen 3 mechanics and none have given the problem I hope they can help me since the I'm really frustrated with this
