flashback
- Joined
- Jun 28, 2002
- 4,152
I recently changed the gimbal bearing and being the curious sort I took my old bearing apart. The tolerance ring has a gap in it that aligns with a hole in the carrier which in turn aligns with the grease fitting on the housing. When I removed the bearing from the carrier I found a channel around the inside of the carrier and 2 small (paper clip diameter) holes in the outer race of the bearing that align with the channel. I guess my question is how can a sufficient amount of grease get into the actual bearing thru those 2 holes? You can pump grease all day long and it mostly comes oozing out between the carrier and the outer race but once you stop pumping there is no longer any pressure on the grease to force it into the race.
Yea I know, I sometimes think myself into a box sometimes.
