Wolfgheist
Thread starter- Joined
- Aug 24, 2021
- 37
And anyone know where to get a physical copy of the engine manual?
Exhaust tube rather than exhaust bellows. Just easier to install.I got my Bellow Kit, but it was mentioned that a Bellows Tube is better? Should I get that? If so, where? I am not having luck finding a bellows tube kit anywhere.
Yesterday, if I put gas in the chamber it fired up no problem. I tried tapping on it and no luck. Fuel is not making it from the pipe to the chamber. Will spraying carb cleaner or air into the intake where the fuel is being blocked work to open it up until I rebuild it later? Three day weekend and really wanted to get out on it.Float may be stuck. You may be able to tap on the carb to free it up but you probably need to rebuild the carb. Pour a little fuel into the carb & with the flame arrestor ON see if it fires.
The float may be saturated with gas or sticking. You can remove the top of the carb to check it. Carb cleaner won't do anything if that is the issue. There is no mechanic in a can. Sorry.Yesterday, if I put gas in the chamber it fired up no problem. I tried tapping on it and no luck. Fuel is not making it from the pipe to the chamber. Will spraying carb cleaner or air into the intake where the fuel is being blocked work to open it up until I rebuild it later? Three day weekend and really wanted to get out on it.
It was the carb. Worked great after I rebuilt it.Could be a problem with the fuel pump?
