1987 alpha one 175 noise coming from bellhousing
Clarko1988
I have a video of it it's comes and goes. When I accelerate it get quieter. Mainly does it at idle.
Clarko1988
It's not the motor it is coming from the bell housing area also I just bought the motor was not from a dealer
  • 20210630_171201.mp4
Clarko1988
remove the drive and retest
It dawned on me that when I took the motor out there where wood spacers under the front motor mounts that I forgot to put back in...could out of alignment cause this?
Rick Stephens
Checking alignment is an annual maintenance requirement. Checking it every time you pull the drive is a must. Not checking it when you swap motors is like not bothering to put oil in the motor.
I
Pulled the motor checked the flywheel torqued everything. Can't seem to find the problem.
you did pull the drive first, then re-align the motor and check the gimbal bearing and u-joints before putting the drive back in, correct?
tank1949
Ouch! I assume you pulled and installed new motor? I saw shims on old OMC drives years ago but not on MC, yet. That's new to me. Pull drive and check for alignment, gimbal bearing roughness and then u-joints. Pray you didn't damage coupler or spine teeth. Crank motor w/o drive attached. You will have to use garden water hose and jurry rig supplying water. If no noise before re-installing drive, pray noise is not in OD gears. You will know soon enough. Good luck!
