Rasdiir
- Joined
- Jul 18, 2011
- 181
Hello to all you tin craftsman, I've been reading all of your restorations for years and now I finally have the chance to try my hand at my own rebuild! Although I have been on the water a few times with friends, this is my first ever boat to actually own and drive, so my knowledge is somewhat limited. I live on the shore of a decent lake near Kingston, Ontario, so I intend to use this boat for both fishing and cruising/tubing with the family.
A few weeks ago I picked up what seems to be a somewhat rare model, the 15ft Super Sport (SS-150). I paid too much for it, but that's the market here in Canada right now. The HIN plate on the transom was removed by a PO (I'm hoping to find a secondary during the teardown, my understanding is that manufacturers often hid a backup under fittings in the interior), but from the decal pattern and referencing pictures of other models I have narrowed the year down to somewhere from 1983 - 1986, does that seem right? I have searched everywhere I can think of and haven't been able to find much information on this boat, and have only been able to find two for sale that had pictures I could reference, so if anyone has any information on it I would love to hear it! The PO replaced the floor and transom (somewhat badly, they are just painted instead of sealed and he left the original foam) and also did some trailer work, although much more is required.
The boat came with a 1985 Yamaha 90hp 3-cyl (90-ETLK) that is quite clean and seems to run well to my novice ear, although it is slightly overpowered for this hull (capacity plate states 80hp). I have read that this is a solid reliable engine and is fairly light for its size (NADA states weight as 260lbs) so I'm still debating if I want to keep it or trade for a 70 or 80hp, any thoughts? The boat does sit fine in the water and really doesn't seem heavy at the rear even with three people.
I have been planning this for years as I went through all of the great builds on here, and I started specifically planning the day I picked up the boat, so the slightly more detailed list for the build is:
Anyway, I am quite certain that I will have a million questions as I go through this process, and I'm very excited to finally get started after years of looking at others! All thoughts and comments are welcome!
Cheers,
Jared
- Teardown to bare hull. After 4 hours on the water I have only noticed a small amount of water in the hull , maybe 1-2 litres total, but I want to do this build right and get it as leak-free as possible. The hull and rivets seem to be in fairly good condition (although the roller trailer has left a series of divots) so I'm hoping not too many rivets require replacement, although I will learn how to do that too as I'm sure it will come in handy throughout this process. The splashwell has some cracking in the corner and the knee brace tabs are broken and had a repair done by a PO which I will redo again, so I will be paying particular attention to beefing up the structure in the rear when rebuilding. Although probably not required, I would also like to add braces between the stringers and possibly the rib end braces if they are not already there, thoughts? I will be using the usual pink or blue foam wrapped in fuel-proof plastic for flotation.
- Floor/transom: I'm still debating the best sealant, I've never used epoxy so was leaning toward spar varnish, although I've read some people have a problem with adhesive when installing the floor covering? I would like to use Nautolex for the floor and the bow seating platforms (which are completely missing and will have to be built from scratch, I like the aluminum frame that FIGMO used in his SS16), and possibly for the storage boxes beside the splashwell. I also want to make a drop in casting deck for the bow seating area, so the aluminum frame will be easy to adapt for that idea. I have a bit of work to do on the transom, I have noticed one small corroded area near the top and a PO also made a mess of the transom trim, so that will have to be made from scratch as well. The transom end caps are a diy from a PO, so I'll have to either fix them up or find new ones.
- Painting: A full repaint is in order, but the admiral and I haven't chosen a color yet (debating between maroon, grey, and white or navy, grey, and white). We both love this paint design and decals: https://www.ohiogamefishing.com/attachments/100_0767-jpg.20536/. I will be picking up a HLVP from Princess Auto and will learn how to use it on the trailer rebuild.
- Interior: Driver seat will likely be replaced with a pedestal, and I haven't decided on a plan for the passenger seating yet. I would like to keep the back-to back seat style but make the whole box removable with a pedestal mount underneath for when it's just me and a buddy fishing, but I haven't figured out a good attachment system yet for the box. I also need to figure out a way to keep the bow cushions secure while also easily removed for fishing duty. I plan to do carpet on the vertical sides and possibly also the rear storage boxes, as all vinyl on the rear splashwell and storage boxes may be a bit too much of a fishing boat look.
- Motor: Although the motor seems fine I will be taking it in a few weeks to a nearby mechanic for a full inspection and proper winterization. I also plan on changing the impeller, water pump, spark plugs, and getting the carbs cleaned if required at this time. I have noticed a bit of stiffness when shifting and also a bit of play in the steering, so that will also be addressed during the build.
- Trailer: I have a very solid but not great for the boat EZ-loader, model and year unknown as the PO had it registered as homemade. There are currently rollers on it, but I want to switch to bunks to stop denting the hull, thinking about 2x outer and rearmost bunks being a 2x6 on edge and the two inner forward bunks being 2x6 flat. The tires, axle, lights, and front stand are newer and everything works, but the entire trailer needs a paint job, new hardware, and I also want to add side bunks for easier loading and a safety chain from the frame to the bow eye. I'm hoping switching to bunks will also allow me to get the boat 3-4" lower on the trailer.
- Other: I would like to add a trolling motor on a removable mount, and a second battery under the bow seats for the trolling motor and all accessories. Although the current wiring seems decent I will likely be redoing it all. Boat will be trailered and stored in a portable shed, but will occasionally remain at the dock for a day or two at a time, so I have all of the original canvas for the zip and snap together mooring covers, as well as the frame, and I will also be trying to make new covers that aren't ugly brown and 45 years old! Most of the aluminum trim is in decent shape, so I will be polishing it up. I will need new rubrail and the seal for the window frames above where they screw on. I would like to add some LED interior lights under the gunnels, and also fab up some small bow rails as I love that look!
- Budget: Not fixed, but less spent is always better! I donèt intend to go too high end on this build, but I do want to do it right and solid.
Cheers,
Jared
