76SeaRay
Thread starter- Joined
- Aug 24, 2017
- 1,071
So, now that I have the engine bolted to the transom plate I am trying to align it. I haven't been able to get the alignment tool to slide all the way in. I watched a video where the guy used a 1 inch pipe to show what direction the engine needs to move. I don't have a pipe available right now but since I haven't reassembled the upper unit, I decided to see if I could use the driveshaft. Much to my surprise it slides right in and out all the way with the u joints right up to the gimbal bearing without any resistance at all. Why would the actual driveshaft slide all the way into the gimbal bearing and splines whereas the alignment tool won't engage the splines at all? I have used the alignment bar once before and was able to get it to slide into the splines but not this time.
