Mechmagcn
Thread starter- Joined
- Nov 25, 2018
- 149
Hi folks! I had posted that I thought this motor was running on 2 out of 3 cyls. dealer says it's running on all 3.
A little history, a few weeks back I ran out of gas on one tank and switched to the other. After doing so the motor would almost plane the boat and then act like it was starving for gas. I replaced the water separator filter and checked the screen on the motor, both had little water in them. Talked to my dealer and he suggested changing the spark plugs, this helped a little, but it still had no power and wouldn't plane the boat. Took it in to the dealer because it's under warranty. Tech says the fuel system is full of water and debris, I know better because I just checked the screen and there was absolutely no debris there. Of course this wasn't covered by warranty, so $300 later I'm back in the water.
Still no power and won't plane so I took it back. Tech says they scanned it, 55.3hrs., 42PSI fuel pressure, and no codes. Ran it on muffs, even put it in the water. They say there's nothing wrong. They even had tech support online with the scanner hooked up.
I'm sorry, but the day this started it would push the boat 24MPH with 2 people in it, now it struggles to get 15 and won't plane. The dealer tried to say the boat is waterlogged, I agree it is, but it's been in the water for 8 years and is no heavier than it was 18 months ago when this motor was installed.
I'm out of options here, hopefully someone here can give me some insight on what is going on, my dealer has given up. Cooler weather is on the way and this is our daily transportation.
Here's the boat before the new Tohatsu.
