Thirsty Endgrain
Thread starter- Joined
- May 30, 2020
- 254
Well I was out in the open ocean (nearshore), and after switching my fuel tanks to make sure I had plenty for the ride into the mouth it simply wouldn't restart. Ran all day just fine before that. Switched tanks, primed bulb until stiff, and just nothing. Ended up killing the battery trying to restart. Gave it a few mins between tries, ended up trying the pull cord once the battery died, but nothing. My kicker was still ok to run (so wasn't the gas, I just just filled that tank the day before, not bad gas), but I couldn't very well get my boat through the Tomales Bay mouth in my 17' boat on 8hp.
Had to call CG for a tow.
Next morning, it started RIGHT THE HELL UP. No hesitation. Boom.
I'm stumped. Can these engines become flooded? Should I have waited like 20 mins and then tried to restart once it became clear that it didn't want to start? What could possible be wrong, what should I do in the future in that situation, and what should I check?
Planning to pull the carbs and inspect all fuel lines. I do know that my lower fuel primer line has a leak, it was shooting fuel down when I pressed the key in to prime, saw that when I pulled the cover on the water to inspect after the no start. Could that leak cause the no start? But then why would it start and run the next day multiple times no issue?
Sorry for the long wind, I just don't know whether to keep this engine or spend too much money on something more reliable, because I can't have this kind of thing happen out in the ocean. Thank you in advance!
