Texasmark
- Joined
- Dec 20, 2005
- 15,055
Moving right along. Marine carbs these days are real simple. The moving parts are the low speed adjustment screw, float and needle valve. The adjustments are the float level....usually with the carb inverted, the seam on the float is parallel with the top casting mating flange. The low speed needle valve is usually 1 1/2 turn out from a "soft seat". Final setup for idle is in the water, F gear 675 RPM +/- setting the timing by the knurled screw on the lever arm. Slow speed needle final adjustment is opened up just enough for the engine to take full throttle without bogging when doing the hole shot.
The high speed jet is usually buried in the bottom of the bowl and needs special attention to ensure that it is clean when finished, as are the venturi tubes. I had an engine with an intermittent fuel problem and in cleaning the carbs I was just doing the last of the air blowing out and accidentally dislodged a black speck of deteriorated fuel line in the high speed jet cavity. Problem solved.
Soaking with a good carb cleaner, lots of 100 PSI air blowing things out, a wire down the venturi tube and in any hole you can find....carefully....one strand of a piece of lamp cord wire works great,.,..is hard enough to clean out varnish but soft enough to not hurt anything. Any plates on the carb, remove and clean...I found specks of deteriorated fuel line under a top plate on one engine also. When you replaced your fuel filter, did you happen to cut the old one open and investigate the contents?
You may need a manual to do the link and sync...setting up the carb linkage with the spark advance of the stator linkage.
