RVFR
Thread starter- Joined
- Sep 29, 2021
- 18
I asked this one not only for OMC guys but more for the 4.3 powerplants. I just read something that's kinda weird in that odd way, yet knowing there is definitely a difference between auto and marine engines, I have to ask. Is there more power gain when running the 4.3 on premium fuel where the timing advance is greater vs. reg fuel at 1 degree? The reason I ask is I just got a deal on a 92 Sea swirl spyder I couldn't pass on. It looks to be a fairly fun get up and go boat. When I took it out the first time I played with this and that getting a feel, then time to push my luck,, I was only able to get to 4300 RPMs, and wouldn't you know the speed O wasn't working, still though felt like low 40s. I get back looking for info find this fine place where I read a lot of 4.3 pull 4800-49 easy, now granted I have no history with this boat, yet read its empty weight is 2300lbs then add fuel and stuff it is still under 3000lbs. The second trip with the OEM speed O fixed I saw 4400 RPMS at what was 45mph, I'm thinking maybe there is something amiss here, so once going over all things that could mess this up, I find the timing at around 2-3 degrees, LOL, and I know I topped it off with regular. So this begs my question, can I expect it to pull better setting the timing to 6 and use supreme fuel? BTW it has a Michigan 14.5x19 SS prop on it. I know that would help big time on a car
