Lou C
- Joined
- Nov 10, 2002
- 14,290
If perhaps water is getting to that cyl from a leaky exhaust manifold to elbow gasket the exhaust valve in that cyl might not be sealing 100% due to rust. Might want to do a leak down test. If it shows leakage past the valves esp the exhaust valve I’d remove the exhaust manifold to take a look. This is a 2005 Merc? Should have dry joint exhaust then; not so likely to leak as the old design. If in salt water though could be corrosion in the manifold.
