Hi all,
long time browser, first time poster, I'm not a mechanic, but have experience with cleaning carbs, compression tests, spark checks, the basics for these engines.
Purchased a non-starting 2000 Yamaha 9.9 2 stroke, looks like its in very good shape. Current status is not starting. Compression is 130 on both cylinders, white/blue spark on both plugs, and carb has been cleaned, fuel gets to the fuel bulb and primer stays hard. Exhaust also is unblocked. Spark plugs consistently appear dry, and have not smelt of fuel. I don't believe fuel is making it to the spark plugs.
The confusing part to me.. is it won't start, pop, anything, fuel sprayed down the carb body does nothing, fuel (very small amount) deposited in the combustion chambers causes a sputter. I have held a small piece of fabric in front of the carb intake, the reed valve intake, and the crank case intake (removing successive components to do this). The fabric shows no indication of air flow, and barely flutters, almost looks like its being pushed out.
This leads me to believe that the crankcase has a serious leak in it, as the combustion chambers are pulling enough air in to build the compression, but not from the carb body.
Go easy on my brain, I have a difficult time retaining motor concepts, but stupidly enough, enjoy getting my hands dirty....
Mark
Mark
