Starting and maybe restoring old Mercury 402 40hp
Status
Not open for further replies.
Never heard of the concept of heating the fuel on a 2 stroke outboard.-----I know of / have seen fellows running motors fishing in January and February.------Seen them coming into view during a snow squall.------No fuel heaters on these Johnson motors !!----Fuel cooling maybe on a few Mercury models.
The Force power
1st. we're talking Mercury not Johnson!
2nd. the late 70s 50 hp 4 cylinder or 65 hp 3 cylinder (I'm not sure) had small hoses running through the fuel-pump to pre-heat the fuel
How would it be cooling the fuel if the hot water from the head would run through the fuel-pump?!?
I guess that concept is often misunderstood
Fuel heating on an outboard is just a pile of nonsense !!-----Some folks just do not the simple things.---Explain why you would want to heat the fuel !!!
The Force power
For better combustion
see page #36
  • arch_65151.pdf
merc850
The Merc 400 motor that preceded it had crank breakage problems due to owners over propping them which caused them to run under the rpm range, ie lugging; the fuel pump was water cooled to reduce the possibility of vapor lock and the mercury switch prevented overreving if the motor hit an underwater item that would kick it up. The shocks slowed the motor from rising into the air then cushioned it when reentering.
The fuel pump was water cooled.-----There is a huge amount of guessing in outboard motor land.
The Force power
The fuel pump was water cooled to reduce the possibility of vapor lock
Hi Merc850,
The particular fuel-pump I was Referring to was equipped on an early 70s 65 hp 3 Cylinder Merc. I'll have to take your word for it although I can't see HOW it would cool the fuel as this was connected to the hot side (tell-tail water)
oldcab
If reverse lock does NOT WORK the motor could tip up and over rev with prop out of the water.------Motor will not start ( no spark ) if operator has " ramp fever " and tries starting before checking if motor is in correct position !-----Find a better project motor.
ic, so makes sense the mercury switch is still a very important safety feature
as mentioned a few times now I do not intend to use this engine but also do not intend to bury it in landfill if it still works
It would be nice to have the serial# of the outboard so we would know exactly what unit we're talking about
(2) it has everything to do with in reverse because when the reverse-lock would not work the motor / LU will pop out of the water
(3) and is routed through the fuel-heater/pump
(4) Yes, you're correct
2) my setup got electric tilt trim, that should be safe
3) checked the fuel lines today, definately already routed correctly as per service manual, but missing the lines to the quick release coupler and check valve
and water definately for cooling fuel and pump
tested compression multiple times today
150/155psi
seems to be no spark or weak, i dont have fuel tank with me so no attempt to start it, will confirm when i test the stator etc when i have a chance, wirings seems shot, will see if it's the wiring or stator itself, will go from there
The Force power
150/155psi
You could check if the Mercury-switch is still good by soldering a new wire on & check for continuity by tilting it (bench-testing is easier)
(2) You can hook a fuel hose with primer bulb directly to that & just drop the other end in a fuel jug (jerry can)
You have not mention the serial# so it hard to pin point the exact engine you have, here is link to diagnose the ignition for what ever version you have
oldcab
yup thanks, i'll check the mercury switch last as that's the least important for now, probably easiest way is unscrew it and aligator clip the terminals to a multimeter?
would I need to connect a check valve for the fuel tank or that could be skipped for now?
just tested the stator, red blue wire / within specs
checked the trigger, within specs
one coil is within spec 900 ohms, but the other coil is 5000 ohms which isn't, but the connections inside the coil to the bad one seems charred, although I doubt cleaning it will help
from my understanding I can't check the switch
also I can't find the spec for the yellow/yellow wiring for the stator
but the wires for the stator are shot anyway, to sell this engine to anybody as a working unit I will probably want to have to replace at least the stator, found one local one for about $300
will try to pull the flywheel when I have chance, I've already marked them, will have a close look at the stator to see if I could get right to the windings to solder new wires, never took one apart before, but if I could bandaid fix it, at least I could confirm how much parts I need to get it working if it's worthwhile
oh yea, I'll try to find the serial number too
The Force power
You can check the switch on the motor while tilted up for continuity strip the wire as close as possible at the switch.
The check-valve in the quick-connect has no other function then to prevent fuel leaking out of the hose WHEN disconnected, so no you don't needed right now.
"from my understanding I can't check the switch"
What switch are you referring to??
The two yellow wires are the charging-circuit, I don't know the reading either you can remove one of the connected to the rectifier (for now)
Mercury wiring on engines of this age are all deteriorated, You WILL have to replace most if not all wires inside the cowl, remove the stator and solder on new sets of wires. (as close as you can get onto the old wires)
Pay close attention to all the wire leading to the switch-box.
REMEMBER...bad wiring/connections lead to bad diagnoses
this project will be a be a labor for love, by the time your done you won't want to sell it.
oldcab
ic
was referring to the switch box (332-4911A 8)
yea i got the values, they range from 0.15-0.2 depending on the output of the alternator, so it's not something I could measure with my meter
yup, will try to check out the stator tomorrow, but now I'm baffled at lack of spark, as there is only 2 possible reasoning, 1) switch box, 2) ignition leads, as everything else checks out although wires a bit frayed but the right readings at the terminals, will have to see if I could get hold of a spark tester
yup i've took photos of everything and traced all wirings and the colours matches the circuit in service manual
yea all a bit of fun for me, never worked on a marine engine before, but if I have to start throwing money at it then it won't be worthwhile, looked at the internal and external harness, not cheap, so will see whether I could solder new ones myself otherwise not throwing $1000+ as most likely I will need to recon the carby, and still got the lower unit to play with, just got a bit of spare time while I wait for a 4 stroke so nothing to lose till I start throwing money at it
oldcab
quick update, I made some new battery cables to ensure a good ground because I tried cranking it last and it won't crank thought the solenoid went bad, but new cables sorted it out, and bonus now there is strong spark 6-8mm easily on both coil
I'm pretty confident the engine will start now with good compression and now spark
looks like the engine already good to begin with, just wanted to go through everything as I didn't want to damage it as I didn't know when it was last started
so if it starts, i'll need a minimum new impeller, new LU oil, try to rewire the stator, and see how much wiring I could fix, so should get this up and running for less than $1,000 for anyone that needs it, even with new stator and external harness, better than sitting in landfill
The Force power
That good news but check the oil in the LU first before you do anymore work!
Status
