harringtondav
Thread starter- Joined
- May 26, 2018
- 2,523
My owners manual says to mix two stoke engine oil into my boat's fuel and run it through to get the necessary corrosion protection over winter lay up.
With my previous Merc carbed 4.3 I simply sprayed fogging oil into the carb.
My VP 4.3 is high tech with high pressure direct injection, O2 sensors etc. Is there a reason I shouldn't simply spray fogging oil into the intake/throttle body? This is a non-CAT engine.
If I can't fog the engine, what is the recommended premix ratio of the two stroke oil?
(if i premix things will be smokey for some time next spring. ....got a fair amount of fuel in the tank)
