Bravo 3 gear oil leak
SIMO329
I noticed gear lube on my garage floor and it appears a fitting is broken next to the speedometer fitting in the lower drive. The broken fitting I found there is straight but it appears there is not enough hose to bend and connect the two pieces together. Does anyone know the part number or name of the fitting I apparently need. Bravo gear lube tube.jpgBravo 3 gear lube fittting.jpg
Bt Doctur
a universal vac hose connector but your issue is in replacing that hose without breaking of the end in the transom. Replacement is difficult but not impossable.Attach a razor blade to a dowel and slit the hose to remove it from the transom. Using a 3/16 or 1/4 inch rod 14 inches long with a sharpened tip to cut the clamp and hose on the gimbal side
Bt Doctur
Gear Lube Reservoir Fitting Assy 90Deg, Mercury - Mercruiser 22-861150T02 1635732850270.png​
SIMO329
That hose is no where near the transom. It is next to the speedmeter fitting in the very bottom of the lower u;nit.
SIMO329
Gear Lube Reservoir Fitting Assy 90Deg, Mercury - Mercruiser 22-861150T02 View attachment 352185​
That is not the fitting for where my tubing needs connecting. That is for the upper end connection in the top of the Mercruiser drive. Mine is right next to the speedometer connection in the lower part
Bt Doctur
If gear oil has leaked it leaked from the oil hose from the res to the drive.
Using a length of hose approx 2 inches longer
SIMO329
Nope, it is coming from the tiny hose on the right in the picture. A very slow drip - about 3 oz. a day.
