AKJohne
Thread starter- Joined
- Mar 26, 2017
- 220
I will be using all my accessories, including my existing shift plate with shift interrupt. The base 5700 is the same to my understanding. As you ssid MM builds them for different applications. The only real difference is the 750 vs the 600 cfm carb, as I doubt the delco vs TB offers any increased hp. I am ok with the 10 more hp and I think the drive can handle it ok.The 325 is a mercruiser crate engine intended for bravo drives. The silver package is a partial engine MM puts together from a new base engine. If you have an alpha drive the 325 hp one wont work due to lack of shift interrupt with the bravo TBV ignition module. I think merc makes a 300 hp version for the alphas
Rereading the description makes me think one is a gm and the other is a merc?
