KenleyF
Thread starter- Joined
- Nov 12, 2021
- 12
2006 Volvo Penta 5.0 GXi-G
SN4012207365
Driveway stored in Atlanta, GA area.
Rookie here needing some winterizing tips. I have read many of the threads here but currently experiencing information overload and don't want to make an expensive mistake.
I have found the two manifold plugs but are there block plugs on this engine? If so, where are they located? Is there a total of 4 plugs to pull plus all the hoses to remove most of the water? The way the engine is situated in the boat (Monterey 220 EX) I can't see the block where the spark plugs are must less any plugs.
What is the best "fogging" mixture and should I run it via a tank through fuel filter or just pour directly into fuel filter?
I am already learning lots from you all and any help is much appreciated.
Thank you.
SN4012207365
Thank you.
