it9ozs
- Joined
- Jun 16, 2016
- 25
Hello guys, my name is Salvatore from Italy. I need your help to solve mi problem.
I can't understand what's happening in this engine! Let me to explane...
Engine: Volvo Penta 5.7 GSi PLKD (s/n 4110144796)
Totally remanufactured by myself (pistons, rings, bearings and all the rest....).
After the first start, I tried to adjust the ignition timing at 8 deg. BTDC. Impossible to do...or there is something wrong...
- Base timing mode done using jumper wire and rinda scan tool too
- Timing light at spark plug wire #1
Using the timing light at 0°, the timing mark on the balancer, appare at 12 o'clock (or so), out of scale.
Adjusting the timing light to read the spark advance, the mark go to zero at about 35° BTDC!!
(See the picture attached).
Checks carried out:
- Timing chain and the alignment is right as manual says, but I verified the correct position of the valves and piston with the #1 at TDC and timing marks aligned;
- Ignition module sems working, I tried another one used and result same issue
- Cap, rotor, spark plugs, wires and ignition coil are new
- Knock sensor is working, verified by oscilloscope
- Harness and connectors are good
- Connections from ECM (MEFI 1-2) to sensors are ok
- Grounds, +12 Volts and +5 Volts to ECM and sensors are ok
If I rotate the distributor to adjust the timing, the engine goes bad and dies.
I have somethins to check more:
- Crankshaft balancer (is the same of 4.3 MPI, could be possible?)
- Timing scale fixed with bolts to the timing cover
- Knock module
- Timing light (if is working right)
Somebody can helps me please?
P.S.
Sorry for my english....
Thank you
Checks carried out:
- Knock module
P.S.
Thank you
