demarko210
Thread starter- Joined
- Jan 2, 2015
- 655
What size vinyl will I need to update my canvas enclosure windows? My options that I see are 40, 10, 16, 20, 4, and 8 at the moment.
It would be the front and sides16 or 10 depending on what you are working on
The current one I have can be rolled, which to me rolling will eventually lay flat because of gravity and cause obstructions in my view over time (as it has). Unless you can have it stand upright when rolled up. I did want something on the front that would not roll since they are the smallest sections and the main 3 I use. These sections are all window, zipper, and button snaps. I figure it would be the easiest sections to update. My enclosure is connected to a bimini.It depends if you need to roll up your plastic.40 gage is not gonna roll easily unless its a sunny 90 degree day.20 is the absolute minimum and 30 is the most common on a quality setup.
I was looking at these but do not see anything saying that it is UV treated. However they say it does not turn colors in the sun. Should I be looking for items that say "optically clear" or "UV protection" ? ThanksA lot of plastics you get at a "Michaels" or "Joanns fabrics" look good until you try to see anything more than 10' away throught it.I care about that so I go with marine grade plastic only.If you dont care about optically clear then you can save some $$ but the less expensive plastics wont last as long or hold up to use as well as they dont have the same UV inhibitors.Charlie
You have a hard top right? Would the gauge make a difference if it was connecting to a bimini-top?I have 40 on the front and 30 on the sides and drop curtains
I’ve had both by the same OEMYou have a hard top right? Would the gauge make a difference if it was connecting to a bimini-top?
I will pick up a can of that expensive stuff. I see it works for headlights too! I also need to clean the yellow off my trucks lights. Thanks will update you.I’ve had both by the same OEM
No difference other than the front curtain was 30 mils as well on the Bimini.
Give Plexus a try before tearing into them with a buffer. Does a great job at cleaning and protection
Boy has it gone up….I paid $17 a can delivered to the house a couple of years ago.I will pick up a can of that expensive stuff. I see it works for headlights too! I also need to clean the yellow off my trucks lights. Thanks will update you.
