OMC SSV-177 Glastron 1979
Hello everyone, first parts are complete of the repair. Engine is up and running. I just checked the alternator and it's not charging. What should the charge voltage be? Is it the same as a car 14.5 volts?
  • 0001-0898.mp4
The OMC steering cable was already loose when I got the boat. Do you have a picture of the bolt area? Maybe I can look on my old parts to get an idea.
My cost is with me doing all the work except that I am having any media blasting and powder coating done by others. I did have to buy a lot of parts that did not come with the boat which is what you face in switching from OMC to Merc. A lot of my cost is buying new parts to replace old bad ones for the Alpha drive plus the cost of marine plywood and lots of fiberglass cloth and resin. I did have a guy glass in my new two layer marine plywood transom and fill the old OMC hole in the hull.
The other cost is in the engine build with the machine shop doing that machining and I bought new pistons and rings, new oil pump, new oil pan, roller marine cam, roller lifters, roller tip rockers, and new pushrods. I went with new HGE dry joint exhaust manifolds and risers and the Monitor Products closed cooling system.
So, mine is a full restoration though. I even disassembled the windows and powder coated the frames as well as removed the rub rail and had it powder coated. I still need to buy new insert for the rub rail.
Wow, that's a real complete restore, Great job,
Furport
Hello,
Thanks for the response. The boat is in really good shape stringers and transom are in good shape as well. The both is worth saving. It has a starter problem. The title motor will not move the outdrive relays click, trim, motor doesn't work or doesn't move the motor yet. Do guys know any tricks to remove the starter on this model. The solenoid works but will not make the starter to turn. Shorted a bar from the brushes to the battery lead and still no operation of the starter.
Are you sure the relay is really conducting the high current? Just because it clicks doesn't mean it is functional. I bought replacements from Amazon. Also, must grease the trim actuator. May also need to refurbish the tilt clutch.
