Installing Rectifier / 9.8 Nissan NSF9.8A2
evane1110
Hey all!
Attempting to install new Rectifier/regulator on my motor. Does anyone have any idea where the rectifier goes? Can’t seem to find diagram in owners manual.
9.8 nissan s#031427XD
m#NSF9.8A2. Rectifier
  • IMG_0853.MOV
  • IMG_0820.MOV
Sea Rider
Check if under or side of the flywheel there's an extra connector to hook the rectifier there...
Happy Boating
evane1110
Having issues figuring out wiring while installing rectifier/regulator on Nissan 9.8. Any ideas ?
evane1110
Having issues wiring the new rectifier. I have red yellow white and ground cable. Any diagrams ?
ahicks
Not clear if you are replacing an existing rectifier, or trying to come up with a charging system knowing that it will need a rectifier?
On the systems I'm familiar with, if you look under the flywheel there will be 3 coils. 1 small one for firing the ignition, and 2 larger coils whose leads eventually end up at the rectifier. The rectifier would have 4 wires. One is a ground, one is the 12v lead (often going to a fuse), then the engine's 12v system(s). The remaining 2 wires, often yellow, lead to the 2 larger coils under the flywheel.
What I'm wondering is if your engine is equipped with those larger coils.
evane1110
Man! Thank you so much. I am replacing an existing rectifier. I’m trying to finish a job that the shitty mechanic didn’t. I have the red down, but there are two yellow and one white existing “plugs” but setup isnt working, I tried different plugs . I need a mechanic ha.
evane1110
Do you think that’s where it’s mounted?
pvanv
If your motor is electric start (looks like it), it has an alternator. If not (rope start only), you will need an alternator in addition to the rectifier. Full info is in the Factory service manual, Part #: 003N210561 List Price (MSRP): $43.75, but FWIW, the rectifier is plug-and-play. It mounts below the oil pressure switch on the port side, behind the CD wiring connectors. Yellow and white are alternator-to-rectifier wires (female from the alternator). Those should be about 1/2 way down the wiring block (cable terminal holder in the FSM). The big red is below those. You MUST ground the rectifier/regulator with a 6mm bolt (10mm head).
evane1110
Thank you. This boat was running a few weeks ago, wouldn’t start. The rectifier has a ground cable but do I also secure it to the motor I assume? I’ll go down and check it out
Sea Rider
Yep the rectifier's ground cable must be bolted to the block as suggested...
Happy Boating
pvanv
Just look at the diagrams in the Factory service manual and all will be clear.
ahicks
All due respect Paul, but if those manuals were handy, I doubt there would be any question here. If it continues to be an issue, I'm in total agreement with you. Go get a manual! -Al
pvanv
Good point Al, but as you know, working without a manual is difficult. The manuals are available from any dealer.
