Kola16
- Joined
- Jun 23, 2019
- 219
Hello all! I have a 2012 Yamaha F20 remote start that started running funny. When I start it up it runs fine for 20 seconds or so, and then it sputters out and dies as if it runs out of gas. The gas is fresh, non-ethanol gas and the fuel filter is clean. It seems to run fine when I rev it, but besides that it dies.
- I've taken the gas cap off to see if it wasn't venting and no change
- I've ran the fuel line from the gas tank directly to the carb while pumping the ball in the fuel line and trying to run the engine and no change.
- I've "cleaned" the carb, but it was already spotless.
- I changed the spark plugs and insured they were both sparking.
- I blew through the air hose to the carb and it was clear
I did drive up onto a sandbar recently. Is it possible that sand went in the water pickup and is causing it to die at low RPMs or something? I'm at a dead end. I'm going to do a fuel pressure and compression test Saturday night...
Thanks for any advice!
