Thomas1981
Thread starter- Joined
- May 26, 2013
- 19
Hello, my name is Thomas and since 8 years boat owner again.
I bought a speedboat with 3.7L Mercruiser 1992 that was standing still for 4-5 years, engine has 300 hour and looks in good condition (see picture).
According to the previous owner the engine was doing fine before the it was put in storage.
The engine was properly winterized, but stored outside.
I want to do a compression test before I start investing money into it.
Yesterday I took the plugs out, and inserted some oil in every cylinder.
But I can't rotate the engine in the correct direction, only opposite direction (CW) of the engine rotation (CCW). Rotating with a spanner, didn't use the starter yet.
But when I turn it 'back' (CW), I can rotate (CCW) it back to the position where was standing for 5 years.
So I can turn the engine in 2 direction each 90 degree, but in both direction eventually it gets stuck.
I already took off the drive but the problem is still the same. The valves are not stuck.
It feels like a piston is hitting a valve, but this shouldn't be possible.
Is there something I can do before I will take the cilinderhead off? The cylinders are from aluminium so I don't expect rust on it.
Is there a component to can block the engine only in a certain position?
When it's rotating I don't feel special resistance and there are no sounds.
Thanks for the tips.
