jeremyjohnolson
Thread starter- Joined
- Nov 15, 2021
- 21
Yes, I was told by Blue Sea tech support that it's best to charge the house battery first because it will be the battery that drains more often. The start battery will only be used once when starting.It looks ok
Your setting it up to charge the house Bats first
Not really, no.Is it OK to go without the two 150 amp fuses between the batteries and ARC?
Well, have to disagree with ya in some respects as it can depend..........Not really, no.
Contrary to popular belief, fuses are actually included in circuits not to protect the device(s) you may have connected, but rather the wiring which makes those connections.
Well, small and mid sized motors have their own internal thermal overload protection. With larger motors you are SUPPOSED to wire in a combo motor contactor/breaker. Of course a lot of people don't include those in their circuits and instead rely on the (false idea) of a breaker as a form of device protection.Well, have to disagree with ya in some respects as it can depend..........
A jammed motor not turning the windings heat up and the enamel can cook shorting the windings together, if current is limited/stopped by a fuse opening, the motor(the device) is potentially kept from being destroyed.
Not all motors have them and if this is the case and the fuse doesn't limited current, the overheating device (the motor) can be the cause of fire, not the wires.The device is SUPPOSED to have its own protection.
Most if not all motors you will find in your house, including hair dryers, heating pumps, sump pumps, a/c compressors... etc, are already thermally protected. They shut down in case of overheating. There is thermal protection woven right into the coilsNot all motors have them and if this is the case and the fuse doesn't limited current, the overheating device (the motor) can be the cause of fire, not the wires.
Yes and that supposed protection is typically a fuse, by which, can and will protect the device from catching fire/dying, not the wiring..........
By "shut down" you mean their internal fuse opened? And they are over thermaling because of too much load current, and too much load current is being limited/stopped by said thermal cutoff, and a thermal cutoff is by definition is a fuse?thermally protected. They shut down in case of overheating. There is thermal protection woven right into the coils
You've focused primarily on residential AC (and motors which you yourself have shown have thermal fuses that can also, and are primarily used/intended to protect the motor, not the wiring).Now with low voltage wiring all bets are off. It's like the wild west of wiring because there is really no universal set rule or standard... which is why threads like this come to life!
You are missing the point that the wire feeding the device is supposed to be sized correctly for the load of the device. The fuse or breaker, if properly sized, not only protects the wiring for overloads or shorts, but also the device.Well, have to disagree with ya in some respects as it can depend..........
A jammed motor (although not electrically "connected") not turning the windings heat up and the enamel can cook shorting the windings together, if current is limited/stopped by a fuse opening, the motor(the device) is potentially kept from being destroyed.
What if in the above case the jam is caused by a *person being caught in the motor? Like an electric window/door and such..... The fuse/breaker opening due to over current AND stopping the motor before perhaps more severe injuries could occur.
If *puppy is chewing on the live extension cord, when he chews the two conductors together, the short's point of contact only makes a "smaller" more controlled limited current arc in his mouth instead of a GIANT exploding sustained 3000A welding arc, thus saving puppy's (the device) life from the more severe injuries/burns.......
Happens for people too(the device!!), esp. so with GFI interrupts, if a body gets between hot and ground(or puppy laying on concrete floor[gnd] and chews on hot) , only uA of current are allowed flow for mS through the person's body,
And breakers and GFI are by all rights, a **fuse as well.
In above cases, sure, the wire didn't melt and catch fire, BUT the devices were also better protected/saved, yes?
*NO animals or people were harmed in the making of this example, the examples were of and for demonstration purposes only.
**The definition of a fuse is an electrical safety device that can stop current from flowing if it becomes overloaded.
You are now taking what I have said out of context... but I think you knopw that. The BRANCH FUSE/BREAKER is to protect the wiring. How one chooses to internally protect their product... internal fuse, internal breaker... etc, can be of many different designs... including fuses. What you have neglected to see or read apparently is that I said just EXACTLY that in post #7:So, these fuses are ALSO protecting the motor from perhaps catching fire, not the wiring.......My point and again, your statement of "fuses are actually included in circuits not to protect the device(s) you may have connected" isn't entirely accurate.
Every device is supposed to have its own protection devices built in, or at least wired to some protection device regardless of the fuse/breaker which is there to protect the wiring. Any store bought device... microwave, tv, stove... etc, will have its own protective fuse built in somewhere. The fact that some people wire in motors and rely on the branch circuit breaker as protection for that motor doesn't make it proper, or change the main function of that circuit breaker.
Stick to your own profession, whatever that may be.
You have mistaken me for someone else. I did not state that......Stating that "fuses are actually included in circuits not to protect the device(s) you may have connected"
Fair enough and my mistake as my impression initially was you were of the volition that "fuses are actually included in circuits not to protect the device(s) you may have connected, but rather the wiring which makes those connections"You have mistaken me for someone else. I did not state that.
Over current devices are meant to protect both the wiring AND the load.
The over current device protects the load device as much as the wiring, that's all I'm saying.
AgreedIt's not there to only protect the wiring.
No problem.Fair enough and my mistake as my impression intially was you were of the volition that "fuses were only included not to protect devices but to protect wires"
There are cases/designs where main feed fuse rating(total current) can be larger than say a circuits components limit (wattage) to where in a failure mode, the current(not the main feed) in the device is such that it can flame up, BUT the main fuse still conducts.....THIS fuse is protect the device, not wires.
Again, consider intrinsic safety designs where the fuse is protecting the components from causation
Agreed
Agreed
Steven J Greenfield
, Studying electricity and electronics from a young age. EET degree.
Updated 2 years ago · Author has 3.4K answers and 10.3M answer views
It is a common misconception that fuses and circuit breakers protect the equipment. But generally by the time a circuit breaker or fuse pops, it is blowing because the equipment or device has already failed.
Fuses and circuit breakers are there to open up the circuit when currents much higher than expected are flowing. The reason for this is to prevent a fire, and also to prevent injury to people. Devices that are not double-insulated must be grounded, so that if live electricity shorts to the exposed metal parts, the case will not go live and the fuse or breaker will blow, removing power.
A circuit breaker and the wire and outlets connected to it are rated to be perfectly safe when drawing the maximum current, with a safety margin. So for instance if the breaker is 15A, the wiring must be sized to not heat up excessively at 15A and up to some safety margin above that, and the outlet must also be built to be safe to some safety margin above 15A.
Then if something fails and draws more than 15A, the breaker opens up, preventing the wire in your walls and your outlet from getting hot and starting a fire.
Fuses are used inside electronic equipment so that they don’t have to design all wiring inside a TV, for instance, to be safe to 15A with a safety margin. Instead, it may have a 3A fuse and then the wiring is safe to 3A with a safety margin.
Also, something like a TV or stereo without a fuse might draw 5 to 10A when it fails and start burning, but the breaker would not open up.
But a TV that normally draws 1A that has a 3A fuse is not going to be saved by the fuse. Because in order to draw more than 3A, it must have already failed.
In motorized devices, fuses are not normally used because motors draw a lot more current on startup. In that case, a small-ish motor may have a built-in circuit breaker that could be manual reset or autoreset.
Correct. There is some (low voltage) wire which is not fused/breakered, and that is a highly debated topic... and it's exactly what I mean when I say low voltage is the wild west of wiring.My 2017 Cobalt came with the Blue Sea ACR. The ACR is connected at the battery switch. The leads from the switch to the ACR are less than a foot each. No fuses. There is no ground metal near the switch or the ACR.
The battery cables that come up to the switch are 2/0. I will have to look to see what the size wires are that go to the ACR. No fuses on those either 2/0 battery cable obviously since they can be used to start the engine.
The reality of using this is that the ACR will never connect two batteries if one of the batteries is below 9.5V. Even if one battery is at that 9.5V and the other battery has the alternator voltage, a wire as little as 10AWG would not melt since you would have so much voltage drop occurring, that the current would naturally be limited.
