When comparing, does it have to be exactly the same model # on parts?Welcome to IBoats,
Will be able to convert a 20 to a 30 provided that both blocks shares the same CC to start with, for other parts compatibility must be compared and replaced if needed checking both models spare parts manuals...
Happy Boating
Okay, i just now checked on my engine and the 1990 30hp version, the carb and intake gaskets are the same, the pistons are the same, so it should work? There is no other ignition or anything else i should be worried about?The engine design came out in 1976.----All versions of this engine design were the same displacement.---It has been marketed as a 15 HP sail drive.( very small intake ports in cylinders ) and as a 35 HP before propshaft rating.-----The block is the same and the 20 hp motors for some years used a different carburetor.----Or the hole on the intake manifold is smaller.------Lower units on later 20 and 30 hp models is the same.-----I have one of those 15 HP blocks ( new ) on the shelf here.
I also now checked and it seems like the 1983 20/25hp is not the same gearcase as the 30/35hp one, the 20/25 one is split into 2 and the 30/35 is one piece. Should this be any concern?The engine design came out in 1976.----All versions of this engine design were the same displacement.---It has been marketed as a 15 HP sail drive.( very small intake ports in cylinders ) and as a 35 HP before propshaft rating.-----The block is the same and the 20 hp motors for some years used a different carburetor.----Or the hole on the intake manifold is smaller.------Lower units on later 20 and 30 hp models is the same.-----I have one of those 15 HP blocks ( new ) on the shelf here.
Glad to hear, how do i go about solving it? Switch over my current choke linkage?The choke / primer issue is a minor bump in your conversion.-----Just my opinion..-----Check and compare the gearcase on the 28 HP specials to see how it compares to your motor !!!
Okay, if i get the carb that has the solenoid, should i tell him that i want the solenoid aswell?I’m with Racerone on this one.
It is an easier swap but not as convenient
The primer solenoid rarely fails and when it does it’s easy to repair.
Okay thank you, i tried finding one online but couldnt find one, do you have any part # or name for the manual primer?The primer solenoid is for remote electric start application.-----The red lever is for manual operation of the primer solenoid should you have a dead battery.-----If you are only using a recoil starter you do not want the primer solenoid.-----There is also a manually operated primer valve that you can fit to the 30 hp intake and carburetor.-----Ask your supplier for that one.----He will have it I am sure.
