- Joined
- Mar 8, 2009
- 44,655
Short story is the title, here is the long one
Had this problem show up around July 2020. A 20 breaker trips ever once in a while. Breaker has 5 outlets and 2 ceiling fans (living room and other on the deck). Things plugged in are Roku stick, lamp (hardly ever used), 2 LED deck lights, 2 - 6V power supply for 2 different propane gas logs
The breaker blew and I trace the circuit and start unplugging things. Never thought to unplug the lamp because its turned off. Came down to I was sure it was the living room ceiling fan because when it was OFF the breaker didn't trip.
Get another fan Dec 2020, install and all good. Everything good until about 2 weeks ago and here we go again. It was right after a local power outage so thought dang it caused the trouble. Replaced wireless control module in the fan and would almost trip right away.
With the fan turned OFF and only the Roku and lamp were plugged in. Unplugged the lamp because that was the only thing left and then noticed all good. Figure in the beginning the LED was drawing some current but was enough to trip the breaker with the old fan which drew more current. The new fan has a higher efficiency so it took months for the LED bulb to start shorting out. I get 16 meg ohms across the bulb contacts, but there is no load
Gremlin in the Living Room with the Lamp, I needed a better clue
