- Joined
- Mar 8, 2009
- 44,272
Yes, same as the one running the basement fire place.The WS PS is just a little wall transformer, right?
So far has not tripped
I agree. There may be something unnoticed tied into that circuit,e.i. doorbell transformer, heat tape etc. I would check the amp load on that circuit with every known device turned off.My money is still on the wiring(or wiring within a outlet)........The WS PS is just a little wall transformer, right?
You can remove wire from breaker and series it through a low wattage light bulb (incandescent) and back to breaker. With everything off the bulb should not be on.Tried that, went out to the shop and got my clamp meter and it wasn't working, hadn't been used in many years. Open it up and battery leaked and damaged it. Might get another for one time use
You then jarred things around by unscrewing and putting thing back together?I wrapped electrical tape around the side screws on the outlets in the metal boxes.
So my guess would be that maybe in the process of moving/jimmying things around while taping screws off, it bumped/jarred something just enough that it isn't shorting now..........a hot was bumping up to either a neutral(white wire) or earth (metal box/bare copper) where some insulation is worn thin(or nicked) in a tiny tiny spot somewheres.....That said there isn't any way the screws would contact the sides once screwed in place
