gohawks688
Thread starter- Joined
- Jun 8, 2015
- 70
Ok guys I am having an oil injection alarm on my 1999 mercury 175 two stroke salt water series. If needed I can provide serial number. Upon start up it has a continuous beep beep beep alarm. I have a factory service manual and have trouble shot the following items.1. Oil reservoir float sensor does not have continuity. This is what the manual says it should be.
2. Checked the voltage at the coil tied to the alarm module with DVa adapter. It checks out within spec.
3. Removed oil pump and inspected plastic crank gear. Gear looks to be in good shape.
4. While trying to trouble shoot the oil pump rotation sensor the first step is to ensure that the alarm module is supplying 12+/-1 volt to the rotation sensor. I'm only getting 9 and change. I don't think I can reliably check for the 5v pulse every two revolutions per the manual of the sensor isn't getting proper voltage. Is this a sign that my alarm module is on the fritz? That is the way Im leaning.
I am having trouble sourcing parts for the module. The part number on the side of the module is 41470a23, I can not find a perfect match for the life of me. I can find 41470a25 and 26 modules. Marine engine also lists the a26 module for my engine. Does anyone know the interchangeability on these modules?
Thanks for the help....
